Rotating strechers
David Giesbrecht
Rotating strechers
Postby David Giesbrecht » Wed, Dec 21 2016, 12:46PM
Hi has anyone else had issues with placing strechers when they are rotated? If you place them you can rotate them. As soon as you try adjusting the placement after rotation they go wild! If I remember right the issue started at version 6.0 ???
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
David Giesbrecht
Re: Rotating strechers
Postby David Giesbrecht » Wed, Dec 21 2016, 1:16PM
Also, if you rotate a strecher you have to make sure the rotation lock is not on or it goes wild when you return to strecher screen.
David Giesbrecht
Z270x-Gaming 5 MOBO
Tracey Marini
Company Name: Crane Woodworking
Postby Tracey Marini » Wed, Jan 04 2017, 8:44AM
If you're talking about changing the angle of a stretcher, then yes, I've noticed that too...it's kinda funky.
Tracey Marini
Crane Woodworking
Norwalk, Connecticut
Scott Marshburn
Postby Scott Marshburn » Wed, Jan 04 2017, 9:35AM
Adjusting rotated stretchers can be tricky.Here is a video where I demonstrate how I adjust the rotated stretchers for an octagon column starting at the 05:07 mark.
https://www.youtube.com/watch?v=hSKt4q_ ... Zx&index=3
I hope this helps.
