No visible nodes
Carmen Addamo
No visible nodes
Postby Carmen Addamo » Mon, Aug 21 2017, 8:49PM
Since the last build I cannot actually see any nodes. Everything works as if the node is present but not able to see them. I can align parts, measure , move walls etc. but I am left guessing until I complete whatever function I am attempting to preform. Same issue on multiple computers. Anyone have the same issues or any possible explanations.
David Giesbrecht
Re: No visible nodes
Postby David Giesbrecht » Tue, Aug 22 2017, 5:10PM
The node you are speaking of are they the same as the ones that show up when you hit "M" on the key board? Or is it the "grid" on the room layout...
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
Carmen Addamo
Postby Carmen Addamo » Thu, Aug 24 2017, 11:35AM
David is your attachment from the main screen of the cabinet editor? If I press the "M" key I get no nodes in cabinet editor. In my attachment you can see I am able to measure point to point but there are no visible nodes at the endpoints of the red line. Same thing if I try to move a wall in custom layout. I can highlight a wall and click on it's corners (anchoring points) and move the wall but no blue or red nodes are visible to let you know an anchor point has been selected.
Clint Buechlein
Company Name: Thermwood Corp
Postby Clint Buechlein » Tue, Aug 29 2017, 8:47AM
Carmen Addamo wrote:David is your attachment from the main screen of the cabinet editor? If I press the "M" key I get no nodes in cabinet editor. In my attachment you can see I am able to measure point to point but there are no visible nodes at the endpoints of the red line. Same thing if I try to move a wall in custom layout. I can highlight a wall and click on it's corners (anchoring points) and move the wall but no blue or red nodes are visible to let you know an anchor point has been selected.
Carmen,
I would suggest making sure your graphics card driver is up to date from the manufacturer. Don't check through Windows, it can give you wrong information or get you the wrong driver. Always go directly to the manufacturer's site for driver updates. I'm curious, if in Settings/Preferences, check the boxes for Force Software Rendering and Use Graphics Double Buffering. Restart eCabinets and see if the nodes appear for you. In the main screen of Cabinet Editor you should be able to press and hold M on your keyboard to display the nodes.
Carmen Addamo
Postby Carmen Addamo » Mon, Sep 04 2017, 9:06AM
Clint thanks for your suggestions. My first thought was graphics card but being the issued appeared on different makes of PC's I dismissed it. Will try your suggestions.
Carmen Addamo
Postby Carmen Addamo » Mon, Sep 04 2017, 9:13AM
Okay Clint. To resolve the problem I had to un-check "force software rendering". Thanks again for your help.
Users browsing this forum: No registered users and 19 guests
