Working with End Panels
Carmen Addamo
Postby Carmen Addamo » Tue, Oct 31 2017, 2:32PM
We use a lot of door matching end panels with our face frame cabinetry. I like that ecabs allows me to choose a matching door style end panel and puts it in place. What doesn't work for me is that if my frames have any more than a 3/4" scribe the end panels are always placed right next to the left or right side when I want it placed flush with the scribe. My only way around this issue is to make the cabinet an assembly. I hate assemblies in ecabs. Several assemblies in a large project is just confusion. Numbering cabinets and assemblies in the same project is literally impossible.
If I use a stretcher for an end panel and modify it in part editor it won't show up in the door list and is too easy to forget when outsourcing doors. End Panels are also not supported in part editor which is another issue. How do you guys handle door matching end panels.
tim lucas
Re: Working with End Panels
Postby tim lucas » Wed, Nov 01 2017, 7:07AM
Good morning,
Are you creating a display door like this and then using the align function ?
This cabinet has a 1" scribe on both sides and I added a display door and aligned it to the scribe on the left.
Tim
www.TLCW.us
Carmen Addamo
Postby Carmen Addamo » Thu, Nov 02 2017, 3:51AM
Tim, I like to make cabinetry that is resizable. I made a library labeled "door only". Basically just a frameless cabinet with no back. Depth of cabinet is set to 1/8" and the sides/top/deck are turned into phantom parts. So now I have a door only which the style of door can be easily changed to match the project door style and it is easily resized. That door will also show up in my door list where a display door will not.
I then use the align function as you do with your display door. Problem is now that cabinet is two cabinets and thus an assembly. Ecabinets can't handle assemblies and cabinets in the same room. It gets confused when you try and bring the project into line drawings for numbering.
This is where the "add end panel" function comes into play. It resizes with the cabinet and door style is easily changed. Problem with end panels as mentioned prior is they remain fixed directly to cabinet side.
tim lucas
Postby tim lucas » Thu, Nov 02 2017, 6:13AM
Ok I brought a base cabinet into the editor selected Doors/Drawers on the right side menu, added a Conestoga CRP10 door sized 24w by 29.5H (I have a 5" toe) aligned the door to the right side, unchecked all cabinet parts. That left just the door on the right side. Saved cabinet, created a room added another cabinet then added just the door cabinet adjusted spacing between cabinets as it did not want to space correctly.
The door shows up in the cut list like it should, you should not have to resize it as it is just an end panel and you should only need a base and different height wall panels I think.
I used global adjust features and changed the doors and it will not change but it does show in the cut list so it seems that would take care of all except changing doors.
You wont need to make this an assembly as you can take the Door Only Cabinet directly in the room, and resizing wont be necessary as it is a cabinet by itself.
Here is my Rt End panel only cabinet, I hope this helps
Tim
A door.jpg (5.71 KiB) Viewed 1515 times
A door.hsf
(112.02 KiB) Downloaded 36 times
www.TLCW.us
Carmen Addamo
Postby Carmen Addamo » Thu, Nov 02 2017, 2:00PM
Tim Thanks. That was a big help! Always thought "add end panel" was my only option of adding a door as an end panel.
Postby Donald Thomson » Sun, Oct 07 2018, 1:55PM
Carmen Addamo wrote: I like that ecabs allows me to choose a matching door style end panel and puts it in place.
I know this is an older post, but I was wondering how this choosing a matching door style end panel and putting it in place works? I've been thru all the editors and can't find this. Thanks!
Carmen Addamo
Postby Carmen Addamo » Sun, Oct 07 2018, 9:57PM
Don, when in main cabinet editor window, in the right side menu, you will see "display door" box. Open that up, choose a door style and size and create the door. Highlight it and you can rotate it and move it around as with any display part. Don't forget to associate it to the cabinet.
You also probaly know that you can also right mouse click menu in main cabinet editor window and click on" add end panels". But these are fixed right next to the left/right sides of the cabinet/ No option to move them.
Postby Donald Thomson » Mon, Oct 08 2018, 11:02AM
Thanks Carmen!! I haven't seen this before. It is all the way at the bottom of the menu and I normally don't use anything that far down.
Users browsing this forum: No registered users and 18 guests
