Resizing Display Boards
Postby Donald Thomson » Fri, Mar 02 2018, 12:15PM
I can't find anything in the Help manual about using the Display Board function. So here goes.
I've put some display boards in a cabinet. I have associated those boards with my cabinet. When I resize the cabinet, is there a way I can also resize the display boards, or do I need to delete them all and start all over again adding them to the cabinet (waste of time)?
Thank you.
Scott Marshburn
Re: Resizing Display Boards
Postby Scott Marshburn » Fri, Mar 02 2018, 3:27PM
Hi Donald,
You will have to resize them manually. I use stretchers rather than display boards. If I need them to be out of solid stock. I use a sheet stock that is named solid stock. to allow them to be filtered out at the machine. I have a video that I show how to use stretchers to make fluted moldings that will resize with the cabinet. here is the link if you want to check it out. https://www.youtube.com/watch?v=kJ3hr2L ... 5ExtuSU0e2
Postby Donald Thomson » Fri, Mar 02 2018, 3:41PM
Thanks Scott. How do you resize a display board? I can't find in the help files how to do this.
Postby Donald Thomson » Fri, Mar 02 2018, 3:51PM
I've attached the cabinet with associated display boards. Every time the customer wants to make size changes all the display boards don't fit.
There are 3x3 posts at each corner, 1x1.5 "stretchers" (not eCab stretchers) to hold the slats displayed at the bottom and then the slats themselves. No so concerned with the slats or posts, but the display "stretchers" are subject to needing resizing every time the customer changes their mind.
Master vanity.jpg (15.19 KiB) Viewed 2005 times
Master vanity.hsf
(1.64 MiB) Downloaded 72 times
Scott Marshburn
Postby Scott Marshburn » Fri, Mar 02 2018, 4:07PM
I am pretty sure that you will have to remove them and add them back at there new sizes.
Postby Donald Thomson » Fri, Mar 02 2018, 5:19PM
Thanks Scott.
I've subscribed to your YouTube channel. I look forward to watching your videos and learning a bunch of new stuff. Thank you for taking the time to do those!!!
Postby Forrest Chapman » Sat, Mar 03 2018, 10:21AM
To bad they can't be scaled like a display object. I would also like to see an option to lock them to a specific location (post on the corners) so when the cabinet is resized they move with it.
Postby Donald Thomson » Sun, Mar 04 2018, 7:09PM
Forrest Chapman wrote:To bad they can't be scaled like a display object. I would also like to see an option to lock them to a specific location (post on the corners) so when the cabinet is resized they move with it.
It would be nice if we could make display boards an integral part of a cabinets design. Be parameter driven like the rest of the cabinet parts.
Maybe something to look at for next release?
Users browsing this forum: Majestic-12 [Bot] and 16 guests
