Reverse sheet order issue
Jeremy Schiffer
Post by Jeremy Schiffer »
In CN 6.08 (THM desktop) When the "Reverse Sheet Order (global)" option is enabled, and offfall is added, the sheet printouts turn into a mess. Load a job, add a piece of material via Add Sheets, check Reverse Sheet Order, and nest. You have to print to a window or a printer for the issue to show.
CS-41 4x8
CS-45 5x12
Jeremy Schiffer
Re: Reverse sheet order issue
Worth a thousand words
CS-41 4x8
CS-45 5x12
Larry Epplin
Post by Larry Epplin »
Thanks for the info Jeremy. We will get it fixed.
