Last line feed speed
Howdy,
I'm using 4.86. I have Last line feed speed set to 300. Outline tool feed speed is 800. I've been getting a lot of parts with the last line feed speed of 800. Anyone else seeing this?
Dave
Dave
Dave,
Try updating to the latest version 4.87 and see if you are still seeing the issue. I had posted a program through 4.87 and it looked good. If you still see the issue, please sent me the file that you are nesting along with the following files from your machine:
C:\\RollingNest\\machine.ini
C:\\RollingNest\\tools.thm
C:\\system\\toolman.thm
Hi Dave,
I've tried to reproduce the situation that you are explaining, but have been unable to do so. The only thing that I might add, I've been testing in V4.91, this may be the difference. If you still see the issue after updating to v4.91, I would like to see the following files:
- .hsf (cabinet file) or .esa (Assembly file)
- .twd file that you are using from ecab
- .cnc file that you've generated at CNC machine
- C:\\RollingNest\\machine.ini (From Thermwood Controller)
- C:\\RollingNest\\tools.thm (From Thermwood Controller)
- C:\\System\\Toolman.thm (From Thermwood Controller)
