Presentation view not working
- Audrey Racine
Hi,
I am running the lastest version of eCabinet and I'm trying to generate a presentation view. I see the software running, calculating etc... but than it stops. Not happen. I reboot the computer, still doing the same thing. Do you have the same problem?
Thank you!
Thank you!
- Audrey Racine
Re: Presentation view not working
I tried to uninstall the program and start again but all the files stay... and when I create my wall I get this... This never happened before.
I am having no problem with it, have you checked to make sure you have the currant graphics update
Tim
Tim
www.TLCW.us
www.TLCW.us
- Audrey Racine
Hi Tim,
Thank for your reply.
I do have the last update.... Is there something else I need to install for the graphic?
Thank!
Thank!
- Audrey Racine
Hi,
I just installed the :
Additional Images:
NOTE: The following link provides an install that will add additional images for use in eCabinet Systems
From the web site. My wall is fine but I cannot generate the view... see picture.
Additional Images:
I am not sure what is wrong - hopefuly Clint will have an idea
Sorry
Tim
Sorry
Tim
www.TLCW.us
www.TLCW.us
Audrey,
At what point are you at? Does the render generate, just not look as nice? Or does the software stop when rendering?
- Audrey Racine
I click on render, I see the system doing the calculation and nothing happen... It just stopped without doing it
- Audrey Racine
Usually when it stops like this I get my cute picture... But now it stops and stay unrender
Audrey,
Verify the below settings are set correctly:
- In Settings/Preferences, make sure Level of Detail Settings for Custom Layout is set to Max
- When in the main view of Render, on the left choose Presentation Settings. Make sure the bullet is set to Full Render, and Pull Detail is set to Max.
- Audrey Racine
Yes everything is fine.
I'm confused because I do this all the time... And it works fine.
I can't explain the problem with the wall also...
- Audrey Racine
I did uninstall ecabinet and install it again and still the same thing. I need to fix this so I can do the presentation to me client.
Audrey,
What is the model of your graphics card and the currently installed driver version? Also what version of Windows are you running? And 64 or 32 bit?
- Audrey Racine
Windows 10 64 bit
Graphic card
NVIDIA
version 388.57
GeForce 949M
Graphic card
NVIDIA
version 388.57
GeForce 949M
- Company Name: JRs Woodworx
Looks like you need to set the tiling of the pattern. Done thru change wall texture.
Users browsing this forum: Donald Thomson and 42 guests
