Any time I manually nest and end up with an empty sheet THM crashes when I write cnc. Pop up says empty sheets will be removed and sheets renumbered. Screen grays out and after a few minutes says software has stopped and must be restarted.
As long as I leave one part on every sheet it writes correctly.
CN v6.11 manual nest crash
Tommy Wieler
Re: CN v6.11 manual nest crash
Same here
Thomas strembitsky
I just had this happen to me today. i can't send crash logs from the cnc for whatever reason but i hope it gets resolved cause i don't know how to delete an empty sheet outside of nest
http://www.trueform.ca
CS43 cnc
CS43 cnc
Stuart Douglas
Can confirm. Often when manually nesting, I will cut a part from the last sheet and try to paste it into a previous sheet. After navigating to the previous sheet, I can't paste the part. It seems intermittent, sometimes it works, sometimes it doesn't.
_____________
NVME SSM2HD 1TB NTFS
- Clint Buechlein
I see the same thing with the empty sheet. I'll pass the information along to the software engineers. Hopefully will have it corrected for next release.
I haven't come across an issue specifically like this, but was seeing some odd scenarios after creating a sheet and scrolling through the sheets. Now I can't get that to reproduce. This is on my desktop PC, only thing I can think is that an update to my graphics card driver corrected the issue. Let me know if you can get the issue to be consistent.Stuart Douglas wrote:Can confirm. Often when manually nesting, I will cut a part from the last sheet and try to paste it into a previous sheet. After navigating to the previous sheet, I can't paste the part. It seems intermittent, sometimes it works, sometimes it doesn't.
- Clint Buechlein
The empty sheet with a crash issue should be corrected with today's release of Control Nesting.
