Cutting into adjacent parts
Rob Davis
Postby Rob Davis » Mon, Jun 10 2019, 1:06PM
I tried to search forum for answer but couldn't find a thread.
We ran these in eCabinets and nested at machine but we are\getting the tools running into adjacent parts. Since nested on Rolling Nest, any suggestions?
Thomas strembitsky
Re: Cutting into adjacent parts
Postby Thomas strembitsky » Mon, Jun 10 2019, 1:11PM
i've had this issue before and the solution it to add a 0.1 mm radius to the tips and it will prevent it from over shooting
NVIDIA GeForce GTX 950
http://www.trueform.ca
CS43 cnc
Thomas strembitsky
Postby Thomas strembitsky » Mon, Jun 10 2019, 1:22PM
CS43 cnc
Troy Hollinshead
Company Name: Leidys Custom Woodworking
Postby Troy Hollinshead » Tue, Jun 11 2019, 9:07AM
Years ago when we 1st got our cnc. I had the same issue. Im not possitive since its been a while but im pretty sure I added a part clearance value and that solved my issue.
Troy
Rob Davis
Postby Rob Davis » Tue, Jun 11 2019, 9:13AM
Thanks Thomas adn Troy. We've cut angled parts before without his issue but never a whole set of them all together.
We'll likely try the radius end first so we don't add extra space between every part in nest.
:beer:
Thomas strembitsky
Postby Thomas strembitsky » Tue, Jun 11 2019, 11:05AM
its good as a double check to go in the graph screen and double check that the cuts are going to hit after you have made you changes
CS43 cnc
Brad McIntosh
Company Name: CNC Automation
Postby Brad McIntosh » Tue, Jun 11 2019, 11:44AM
Rob,
Gouges caused by angle parts are really a factor based on where the intersection of the two edges projects to. If the projection leads to the exterior of the sheet or to a waste area, then you would never notice. The projection is due to the machine extrapolating the offset of the two edges to the point that they intersect. With a 90° or greater corner, this is not an issue as the intersecting point stays "close" to the part. It is only with very acute angles that the "projected" offset path moves further away - the more acute the angle, the further away the intersection point.
The control can't/won't/shouldn't add any entities to circumvent this. As my post back many years ago (2011) may have alluded to - the very, very small radius that one can add to any acute, exterior angles introduces an tiny, imperceptible, extra arc entity in the resultant tool path. This extra arc then allows the tool to virtually pivot around the sharp corner and not delve into other parts.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
