drawer box losing RTA fittings
alainalbert
Company Name: Woodoer Inc
Post by alainalbert »
My drawer boxes are losing their rafix fittings every time I change something in the construction settings. I have to insert them again via Adj Features/Drawer Boxes with Drawer Fronts. This was happening before the update to 6.2.4 and still now.
Has anyone else found this to be a problem?
Is there a solution?
Floating Vanity 2DR.hsf
(1.41 MiB) Downloaded 1328 times
Ralph Balanik
Company Name: Ralph Balanik
Re: drawer box losing RTA fittings
Post by Ralph Balanik »
I would try using the drawer box designer to build a drawer with rafix fitting and save it to "my Drawers" or whatever. Then when you build a cabinet choose your drawer style from the drawer library. That may lock your rafix construction settings rather than setting them up each time you want that feature. I have done other geometry in drawer designer and it has stayed intact whenever I choose it from my drawer library so it may work for the rafix construction as well.
alainalbert
Hi Ralph. thanks for the reply. Unfortunately, these drawers were done in the drawer designer and saved to my drawers with the rafix fittings baked in. there is no reason that they should disappear and in fact, the pre-drilled screw hole which is another RTA fastener I the same drawer is not lost, only the rafix geometry... Strange
