Crown Molding_Ceiling
Postby George Davidson » Fri, Dec 18 2009, 2:20PM
Crown Molding around Ceiling
It can be resized right now it is set for a room 12' x 12'
ceiling molding_12 ft x 7.25 x 12 ft.hsf
(36.02 KiB) Downloaded 230 times
Ceiling Trim_Cr.jpg (35.71 KiB) Viewed 2520 times
Greg Whitman
Re: Crown Molding_Ceiling
Postby Greg Whitman » Fri, Dec 18 2009, 7:15PM
Hi George
Thanks for posting the ceiling molding and for that matter everything else you post. It is much appreciated. When I downloaded the ceiling molding to my import file I couldn't get it to open. I got an "error occured while retrieving HOOPS information to the saved file." I don't know if it is something I did or what. Thanks Greg
Postby George Davidson » Fri, Dec 18 2009, 7:35PM
Did you put it into a yellow folder first
or try the room I put it in
Let me know
Ceiling Trim.esj
(174.02 KiB) Downloaded 205 times
Peter Walsh
Postby Peter Walsh » Sun, Dec 20 2009, 5:33PM
George,
I got the same result as Greg.
I note that it is an esj file which is a job file. Does a job file call for separate cabinet files to be available for loading or is it all included with the esj file?
regards,
Postby George Davidson » Sun, Dec 20 2009, 7:09PM
Just try the STL they will fall right in place around the room
STL Crown Molding_Ceiling.zip
(145.42 KiB) Downloaded 205 times
Postby DanEpps » Mon, Dec 21 2009, 6:27AM
Greg Whitman wrote:...When I downloaded the ceiling molding to my import file I couldn't get it to open. I got an "error occured while retrieving HOOPS information to the saved file." I don't know if it is something I did or what. Thanks Greg
Peter Walsh wrote:...I got the same result as Greg.
regards,
I'll bet George is posting files created in v6 beta, which cannot be open in v5.2.
Return to “Customer 3D Files”
