Hardware favorites
BenRatt
Hardware favorites
Postby BenRatt » Thu, Feb 04 2010, 7:38AM
Do hardware favs and associated holes patterns from 5.2 not transfer over to 6.0? I did choose the migrate option.
Ben Ratterree
Blue Ridge Cabinetworks
Spartanburg, SC
http://www.blueridgecabs.com
Larry Epplin
Re: Hardware favorites
Postby Larry Epplin » Thu, Feb 04 2010, 9:02AM
These areas were eliminated with Version 6. The Favorites becomes unnecessary now that you can simply maintain your hardware items yourself. There is no need to keep all items you do not use in the system now that the store has been removed.
BenRatt
Postby BenRatt » Thu, Feb 04 2010, 10:02AM
Ok, that makes sense. So I need to reconstruct my "favorites"? I noticed the hole patterns did transfer. Why can't you associate a default hole pattern with a particular piece of hardware? That seems like double the work to have to pick hardware and a hole pattern every time.
Ben Ratterree
Spartanburg, SC
Larry Epplin
Postby Larry Epplin » Thu, Feb 04 2010, 10:05AM
Just select the pattern you want to use. It eliminates the need to establish associations. This makes the process much simpler.
BenRatt
Postby BenRatt » Thu, Feb 04 2010, 10:49AM
Ok, I understand that. So I can just ignore the hardware and go off the hole pattern. So the only thing that messes up is the buy list right? FYI- I'm using confirmat/dowel construction. I don't ever place pulls or moldings or lazy susans.
BTW- I do really like the new applied hardware interface that lets me select all left edges at once and change the kd fitting. See we use confirmats unless we have a finished end and then we use a dowel. That's why I have to change a lot.
Ben Ratterree
Spartanburg, SC
Larry Epplin
Postby Larry Epplin » Thu, Feb 04 2010, 10:55AM
You can still set up a hardware item as well so your Buy List will be correct. Now that you can input your own pricing it will also be accurate in regards to where you do your purchasing.
eCabinets always had the ability to set edges on a single part differently for KD. The new interface just makes it simpler (see a reoccurring theme here? ). Glad you like it.
Users browsing this forum: No registered users and 16 guests
