Adding a drawer and drawer box V6. Can someone help me understand the Drawer Front Slide Mount and in particular how the hole pattern works. I'm trying to add the Hafele Metal Box with the Front Fixing Bracket but can't seem to understand how that Slide Mount hole pattern works.
Fred
Fred Hirsch
Re: Drawer Front Slide Mount
I think that this is used if you have a face frame cabinet and use the Slide bracket that mounts to the back of the cabinet (so that the slide only mounts to the face frame and sits in the rear bracket). So the hole pattern would be applied to the back panel. This is how I understand it, but have never used it.
Dell Precision M6400
Core 2 Duo T9600 2.8GHz
4GB Ram
NVIDIA Quadro FX 2700M (6.14.11.9562)
Windows XP Pro 32bit
4GB Ram
Ben,
Thanks for the quick reply. I did an experiment and I'm not seeing the hole patterns on drawer front, face frame or back of the box. Just not sure how this works and not finding any documentation. If this really does put hole pattern on back of drawer face, it would be a real time saver.
Fred
Fred
Fred Hirsch
- Company Name: Sean Jakob Cabinets
Fred
It doesn't put the hole in the back of the drawer for the front fixing bracket, but I sure agree this would save lots of time and frustration if it did.
Sean
eCabinets Team:
Is there a chance that this feature could be added so that not only do you get the slide holes in the carcase, but you also get the front fixing clip hole in the back of the drawer face. Kind of similar to the hinge pattern which drills the hinge plate holes in the carcase and and the hinge holes in the back of the door.
Sean
eCabinets Team:
Sean,
Thanks for clarifying. I saw the hole pattern option and hoped for the best .
Fred
Fred
Fred Hirsch
- Country: AUSTRALIA
Sorry to be a squeaky wheel, as i've said it before, but I DESPERATELY NEED THIS FEATURE. Having to manually put in drill holes and constrain them every time i change the height of a draw is maddening and time consuming. You can do dovetails, and put hinge holes in back of doors but not this. Please put it on the high priority list.
www.eastcoastultimate.com.au
