Build2 1b
Bryan J Tanner
Company Name: Decor Designz
Build2 1b
Postby Bryan J Tanner » Thu, Feb 25 2010, 11:26AM
For those of us that have installed 1a, should we now download and install 1b?
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
Larry Epplin
Re: Build2 1b
Postby Larry Epplin » Thu, Feb 25 2010, 11:35AM
Not necessary. It is only an installer change.
Derrick Monson
Re: Build2 1b
Postby Derrick Monson » Thu, Feb 25 2010, 1:12PM
I Installed Build 2 and lost my hardware, materials, and dynamic markups.
I just did a system restore and was unable to retrieve anything lost.
Should I now reverse the system restore? Install Build 2 1B? Or is there something else I should try?
Derrick
Gateway E6100 / Pentium 4 / 2.8GHz / 2.56 GB RAM / Radeon X1950 Pro XGE 256MB / XP Pro
Larry Epplin
Re: Build2 1b
Postby Larry Epplin » Thu, Feb 25 2010, 1:44PM
Derrick,
I do not recommend going forward with a system restore. I do recommend downloading the latest Version 6 Build 2 installer and running it. (NOTE: If you get the option to Repair. then select this option) This will insure the application runs properly after doing a Windows System Restore.
Unless you have a backup of your data there is no means of recovering the information at once. You will need to re-enter your markup values. The material and hardware can be added by loading a cabinet, assembly, or job that contains the data to help re-establish things. Sorry for the inconvenience.
Derrick Monson
Re: Build2 1b
Postby Derrick Monson » Thu, Feb 25 2010, 1:49PM
I've already done the system restore. I assume you are saying not to reverse it. I will go ahead and install build 2 1b.
Derrick
Users browsing this forum: No registered users and 20 guests
