Hi,
Is there a reason why when I try to take a display object like a sink or microwave, when I select it and try to take it into a room, it blinks in the bottom left corner of the room and disappears never to return???
Rick
Cannot use dislpay objects
Re: Cannot use dislpay objects
You might need to post your job. I just tried placing a bunch of Display Objects and I had no problem. I placed them into an empty two-walled room.
Display Objects don't get placed like cabinets do, they just pop up in what appears to be the center of the room.
Joe
Joe
CFT411 http://www.cft411.com
I think they may be hiding under my kitchen island.??? .. Yep.. i moved the stove and they were all under there. 4 microwaves, 2 sink faucets and a stool or 2.!
- Attachments
- mihalkoecab.jpg (88.79 KiB) Viewed 4607 times
One trick for taming Display Objects is to open them in the Cabinet/Assembly Editor, rotate them as desired and then save them as an assembly. You then place them as an assembly. This gives you a lot better control when placing them in a room.
Joe
Joe
