Loading wall assemblies into room layout question
Postby Mark McCallum » Sun, Mar 28 2010, 8:04AM
Hi Guys
My dumb question time again
I am trying to place a two piece assembly onto a wall. Both cabinets in the assembly are made from upper seed cabinets. I can load them individually into the room editor at the predetermined wall height and place in wireframe. No problem.
When I load the assembly made from these units it loads at floor level, I have tried another wall assembly. Same result.
I can move it in elevation mode, but I don't think that is the intended method of placement.
Is this how the room layout worked in earlier versions?
PS I do miss the align objects dialog from the cab editor not being in room layout
Marie Rich&Wrench2.esj
(3.52 MiB) Downloaded 55 times
Darren Harvey
Re: Loading wall assemblies into room layout question
Postby Darren Harvey » Sun, Mar 28 2010, 9:16AM
i am also having a problem in the assembly section of e-cabs. i can load my assembly, but it set to far back on the screen. and i can not bring it foward. the only thin g that moves is the X Y Z anf target. thanks, darren
coffee and side table.esa
(918.02 KiB) Downloaded 59 times
Postby Kerry Fullington » Sun, Mar 28 2010, 9:40AM
Mark,
All assemblies will be placed at floor level. Place the assembly in the room and use align to back to place it on your wall (or place it in the wall elevation view) then use the position on wall entry boxes to position the assembly properly. Assemblies are done this way because they can be made up of wall and base cabinets and the software doesn't know which one you intend the final asssembly to be,
Postby Kerry Fullington » Sun, Mar 28 2010, 9:44AM
Darren,
I think your file is corrupt. eCabinets will probably want to look at it and get info as to how it was created.
Darren Harvey
Postby Darren Harvey » Sun, Mar 28 2010, 12:05PM
thanks kerry, i will send it to thermwood. darren
Postby Mark McCallum » Sun, Mar 28 2010, 3:32PM
Thanks for the reply Kerry. The loading at floor level makes a little bit of sense.
After it is loaded, so far I have tried, Move in wall elevation, it just jams up, I can use control right click but it will not place properly.
I just can't get this slippery little sucker into position!
I've spent a good 2 hours trying to place it. I've given up.
I'll buy anyone who can do it using metric sizing an imaginary beer. :)
It says 150mm but ......Its not.
wont move.JPG (37.18 KiB) Viewed 1699 times
Postby Donald Thomson » Sun, Mar 28 2010, 4:01PM
Mark,
You probably already know this, but make sure you are in Free Style positioning versus one of the other modes of positioning cabinets. This has bit me in the booty a few times.
Right Click -> Place Cabinet/Assembly Options -> Place Mode -> Free Style
I use this and then the Shift and arrow keys to move the cabinet/assemblies/display objects around where I need them positioned.
Postby Kerry Fullington » Sun, Mar 28 2010, 4:24PM
Don,
I probably confused Mark. I told him to use Align to back to place the assemble in the room and get it associated to a wall. You are correct that he would then be better off to use free style in the elevation view to position the cabinet.
Users browsing this forum: Google [Bot] and 16 guests
