CN FREEZING in 5.57&5.56 ALSO(negative dim -507994920mm)
mohan kommineni
Company Name: ADP STORE FIXTURES
Country: AUSTRALIA
Postby mohan kommineni » Mon, Apr 19 2010, 12:18AM
HI all
we are facing a problem in cn5.57 & 5.56 after loading the job we can find the drawer box sides and front coming up with a very big negative dimension and causing system freeze but practically there are no left and right and front sides on this drawer box as we are using metal slides standard part
what is causing the mess and negative dim -507994920mm
mohan
ControlNest5-57.cab.txt
machine export file
(69.49 KiB) Downloaded 82 times
CC_PF_1155twd.txt
twd file
(224 KiB) Downloaded 83 times
snap shot of negative dimension of drw box which doesnt exist
dimension issue.JPG (124.44 KiB) Viewed 1751 times
Last edited by mohan kommineni on Mon, Apr 19 2010, 12:30AM, edited 1 time in total.
mohan kommineni
Country: AUSTRALIA
Re: CN FREEZING in 5.57&5.56 ALSO(negative dim -507994920mm)
Postby mohan kommineni » Mon, Apr 19 2010, 12:29AM
i have attached the esj file in this post as the previous post was not allowing more than 3 attachments
pls some one go through it and suggest what is causing
thanks to one and all
mohan
CC_PF_1155.esj
esj file of the above counter
(1.25 MiB) Downloaded 79 times
Larry Epplin
Postby Larry Epplin » Mon, Apr 19 2010, 3:06PM
This is an issue with eCabinets that will be resolved in the next update to Version 6. There were changes performed for optimization in Control Nesting that exposed the error from eCabinets. Until the release of Version 6 Build 4 you will need to uncheck these problem parts in the Load screen. Sorry for the inconvenience.
mohan kommineni
Country: AUSTRALIA
Postby mohan kommineni » Mon, Apr 19 2010, 5:59PM
Larry Epplin wrote:This is an issue with eCabinets that will be resolved in the next update to Version 6. There were changes performed for optimization in Control Nesting that exposed the error from eCabinets. Until the release of Version 6 Build 4 you will need to uncheck these problem parts in the Load screen. Sorry for the inconvenience.
hi larry
i can understand what you aretrying to tell here but at this stage how can one resolve the issue in version 6 build 4 when we are using version 5.0 yet
pls avice
thanks
mohan
Larry Epplin
Postby Larry Epplin » Mon, Apr 19 2010, 9:21PM
I recommend upgrading to Version 6.0 Build 4 upon it's release.
mohan kommineni
Country: AUSTRALIA
Postby mohan kommineni » Tue, Apr 20 2010, 1:11AM
Larry Epplin wrote:I recommend upgrading to Version 6.0 Build 4 upon it's release.
hi larry u mean to sAy version 5 is no longer supported or u peolple are forcing us to switch to version 6
mohan kommineni
Country: AUSTRALIA
Postby mohan kommineni » Tue, Apr 20 2010, 1:14AM
hi larry
i also noticed one more issue in cn once nested if gong back into load menu due to any reson all the dimensions are in inches we are using mm
this is really mess try to suggest
thanks
Larry Epplin
Postby Larry Epplin » Tue, Apr 20 2010, 7:33AM
Looks like part width and length are getting multiplied by 25.4 an additional time when returning to the Load screen. This will be resolved in Control Nesting 5.58.
eCabinet Systems Version 5.2 will expire June 1, 2010.
