Drawer box Tongue thickness issue...
MarcoKnjaschewitsch
Postby MarcoKnjaschewitsch » Wed, Apr 28 2010, 9:09PM
So this is since i have upgraded to build 3! I get random Box parts where the same program i ran 1 month ago will cut the tenons to thick!! So i have to shave them down on the table saw to fit the dado..What is going on!!! Even New programs i make in e-cabinets right now will show right on the computer and when i go to nest it they screw up.
Nick M Singer
Re: Drawer box Tongue thickness issue...
Postby Nick M Singer » Thu, Apr 29 2010, 3:40PM
We have just run some MDF drawer boxes with blind dado construction and our tenons are too thin by about 4mm. Go figure!
Larry Epplin
Postby Larry Epplin » Fri, Apr 30 2010, 7:43AM
There was an issue discovered with Build 3 where the dado parameters from the part receiving the dado rather then the parameters from the part creating the dado were being used. I'm not sure if this is what is causing your problem or not. In order for us to insure your problem gets resolved we need some files. Please attach a zip containing:
- the job, cabinet, or assembly
- the twd
- an export from Control Nesting
Nick M Singer
Postby Nick M Singer » Fri, Apr 30 2010, 9:18AM
Larry that does seem to describe the problem. I will generate some files over the weekend.
Postby Donald Thomson » Fri, Apr 30 2010, 11:21AM
This is disturbing to find out considering I'm getting ready to start a kitchen with several dozen drawers - and I make mine with blind mortise and tenon joinery. :shock:
Any chance of a short term workaround or software patch for this ASAP?
Company Name: Halls Edge Inc
Postby Josh Rayburn » Fri, Apr 30 2010, 11:42AM
TWD: :arrow: :idea: Why not just release the patch??? :!:
This has been a known issue for some time now and is causing more dumpster food by the day!
Why does everyone need to scrap parts to figure this out on their own?
Isn't it enough that we're bidding against the landscapers just to get the cabinet work to begin with...then we have to waste material trying to get the job done at (already) slim profits? You have always been fantastic about fixing machining / CNC output issues as a priority, what happened here?
Kenneth Rychlik
Postby Kenneth Rychlik » Fri, Apr 30 2010, 11:51AM
Don,
If they don't fix it quick enough for your job, you can make drawer boxes out of upper cabinets pretty easily.
You have to select the sizes manually, when you batch them, but it's not to big of a deal.
I run mine this way.
Kenneth
Larry Epplin
Postby Larry Epplin » Fri, Apr 30 2010, 1:26PM
Don,
To check your drawer box dados simply do a nest in eCabinets and verify that the sizes are correct. eCabinet Systems 6.0 Build 4 is currently in Beta testing to help avoid unnecessary problems to all users. Testing is going well and we hope to release soon.
Users browsing this forum: No registered users and 10 guests
