Dovetails
Terry Hall
Dovetails
Post by Terry Hall »
I purchased a 5/8" cutter for 5/8" material from Thermwood to dovetail some drawers. The literature that came with the cutter references a cutter with a different number and gives some settings, I'm assuming for a 1/2" cutter. I'm using a shopbot alpha router and the link but I believe the settings would likely be the same. If anybody is cutting 5/8" material would you be kind enough to share your settings with me. TIA
