Per-sheet label printing
Jeremy Schiffer
Postby Jeremy Schiffer » Wed, May 09 2012, 10:14AM
What's the trick to make it work? CN 5.69. I choose the SINGLESHEET file, check the "per sheet printing" checkbox, write the CNC, and it doesn't print. I expected to see some sort of code in the CNC file at the beginning of each sheet to cause the labels to be printed, but there isn't.
I tried again, but after checking the "per sheet print" checkbox, I clicked "print"... and it immediately printed labels for the first sheet. So I clicked close, wrote the CNC, and I still don't see any extra code in the CNC file.
I've read the manual, and it doesn't really explain how to make it work, other than needing to choose the SINGLESHEET label file.
Any suggestions?
Intel Core i7-5820 3.3GHz, 16GB RAM, NVidia Quadro K2200 4GB, Windows 8.1 Pro 64 bit
Larry Epplin
Re: Per-sheet label printing
Postby Larry Epplin » Wed, May 09 2012, 11:41AM
Hi Jeremy. I'm guessing the problem is your version of THM. This feature only works with THM 7.6 or newer.
Jeremy Schiffer
Postby Jeremy Schiffer » Wed, May 09 2012, 11:59AM
My version is 7.2. How do I upgrade?
Larry Epplin
Postby Larry Epplin » Wed, May 09 2012, 12:06PM
Jeremy Schiffer
Postby Jeremy Schiffer » Wed, May 16 2012, 6:29PM
I filled out the form (on the 9th) and haven't gotten a reply. Anybody home?
Larry Epplin
Postby Larry Epplin » Thu, May 17 2012, 8:51AM
Someone should contact you. I'm sorry it has not happened yet. We appreciate your patience.
