need help with item sizing!
Simon Randall
Company Name: westone-group.com
Country: UNITED KINGDOM
Post by Simon Randall »
Hi
I need help with resizing a butt hinge I have a :
DWG (I now this is different but it will still do all the same)
DXF
HSF
files of the same item but when i place the HSF version in to ecabs it is like 4 times the size of the cabinet and I have been trying to get it resized but I can not could someone try this for me so when it comes into ecabinets the size is 64 x 38 mm for me and also if it can be laid out as if it was fitted to a face frame side and in the closed poison.
hafele.zip
(66 KiB) Downloaded 1836 times
Simon
Scott Marshburn
Re: need help with item sizing!
Post by Scott Marshburn »
Simon Here is a hinge similar to yours that I already had see if it l works for you
door hing.hsf
(24.02 KiB) Downloaded 1902 times
Simon Randall
yes that works fine thanks for that.
is there a way of having it auto attached to the door and have the cut out for the butt hinge into a face frame?
Simon
