Thermwood Adds "Personal Pause Button" to YouBuild
Duane Marrett
Postby Duane Marrett » Fri, Oct 05 2012, 2:55PM
Duane Marrett
Thermwood/eCabinet Systems
Daniel Odom
Re: Thermwood Adds "Personal Pause Button" to YouBuild
Postby Daniel Odom » Fri, Oct 05 2012, 5:44PM
Will this work in control nesting or only Youbuild?
Joe Soto
Postby Joe Soto » Fri, Oct 05 2012, 10:14PM
It works with both. I had a chance to use it today. It's a lot better than hitting the e-stop and you can do it from across the shop. Another feature is that the hold down vac stays on while the machine is paused. E-stop shuts my vac off, I'm assuming it does the same on all of them.
I'm not sure if the leave skin feature works with cn or not I will test it next week and let you know.
Joe
Postby Kerry Fullington » Sat, Oct 06 2012, 8:43AM
Joe,
Is it available as a control nesting add-on or is it only available to YouBuild Cut Centers.
How is the YouBuild program working for you? We will be getting the upgrade in the next few weeks and I am curious what the response has been for you.
Joe Soto
Postby Joe Soto » Mon, Oct 08 2012, 8:50AM
Kerry,
From what I understand its part of the You Build upgrade. I believe it's designed to save production time by getting the operator away from the controller to do other jobs but still be in control.
There is a lot of interest in You Build here. I am mostly a cabinet and part cutting shop so I didn't have a lot of contacts with furniture people so its a little slow. But people are talking about it. That's a start. I think once it takes off it will be big.
Joe
Jason Susnjara
Postby Jason Susnjara » Tue, Oct 09 2012, 9:02AM
Hi,
The personal pause button is an option for all machines including 5 axis. With 3 and 5 axis machines not utilizing Control Nesting, the pause button will work but will only allow you to Resume. With machines that utilize Control Nesting, you get more options once the button is pressed. You get the resume feature, replace tool, flycut spoilboard/wasteboard, leave skin on remaining parts or start sheet over. This personal pause button allows the operator more freedom than just being stuck at the machine controller waiting for a project to be completed. This is a "Pause" button, not an e-stop button. The machine will stop and the spindle will turn off once the button is depressed.
Jason Susnjara
V.P., Marketing
Thermwood Corp.
On YouTube:
Thermwood Blog:
http://blog.thermwood.com
Daniel Odom
Postby Daniel Odom » Wed, Oct 17 2012, 12:08PM
This sounds like a great idea.
