G803
Will Williamson
G803
Postby Will Williamson » Thu, Oct 25 2012, 4:53AM
Can you make the G803 the default acceleration factor?
Will
http://www.willmade.com
Georgi Baltov
Re: G803
Postby Georgi Baltov » Thu, Oct 25 2012, 8:53AM
Hi Will, you can add the code in the program header in settings. I've done it on our machines.
Will Williamson
Re: G803
Postby Will Williamson » Fri, Oct 26 2012, 8:33AM
Thanks Georgi is that the factor you used ?
Will
Georgi Baltov
Re: G803
Postby Georgi Baltov » Fri, Oct 26 2012, 8:59AM
Yup.
Brad McIntosh
Company Name: CNC Automation
Re: G803
Postby Brad McIntosh » Fri, Oct 26 2012, 9:52AM
Will,
As Georgi stated you can add that G803 code to the "Header".
You can access the parameter field that via [SETTINGS] -> [SHEET MACROS].
:!: Whatever you place in either the "Header" or "Footer" section will be added to the NC program verbatim, so make sure that the commands are syntactically correct in order to avoid program errors.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
