wont nest "back panel"
Ben Carter
Company Name: Livesound Ltd
Country: NEW ZEALAND
Post by Ben Carter »
hi guys,
I'm new to the forum, first time posting.
I've drawn up a "dj table" in ecabinets and when i go to nest it in our machine it will nest all the parts with the dados but it wont nest the back panels, i've deleted all parts etc off the drawing and tried to nest it as a "blank" piece and still no luck? frustrating as I'm supposed to have this job out the door today.
HELP PLEASE.
Ben
Re: wont nest "back panel"
Hi Ben
How big is the back panel
Ben Carter
1600 x 575 x 18mm plywood
Gerry A Brown
Post by Gerry A Brown »
Hi,
It could be the grain direction. The CN software may be looking for a 1600 mm wide panel. If you are not concerned about grain direction in the CN software chose the material & edit it to having no grain. CN assumes x axis is grain direction.
Gerry
Ben Carter
Gerry, that was it. Thankyou for the prompt replys.
Ben Carter
dado two cabinets in a assembly
Hi People,
Trying to create a assembly with two cabinets that are dadoed together in the back panel, how do i go about this?
Cheers
Ben
Scott Marshburn
Post by Scott Marshburn »
Remove the backs from the two cabinets Then Load a 3rd cabinet that has every thing except for the back removed You can then resize this back to the Proper width and height then align the back to the cabinets using the align tool. Extend the cabinets ends and decks as needed to set into the dadoes in the back. Take the back into part editor and create pockets That will be your dadoes. Then return it to the main screen. Then take the back into constraints manager to constrain the pockets to there proper locations.
Scott Marshburn
Another way is to take a single cabinet and extend its back For example 36 inches on the right the add your second cabinet to get the locations of the pockets then repeat the steps posted to create and constrain the pockets.Delete the second cabinet and save the cabinet with the extended back. This would allow you to resize the cabinets as needed. You would have to adjust the extended back as required for different size cabinets that will be placed next to it.
Dennis Englert
Post by Dennis Englert »
Another method.
Load one cabinet. Setup your basic cabinet for placement of components, i.e., side flush, back flush and assign your overall construction method, i.e., blind dado. Copy and paste that cabinet so you have the second cabinet. Move the cabinets into position aside each other.
In Construction Settings (CS), set the joinery to Blind Dado or Full Dado for both backs. Inset (back inset) the mating Left and Right Ends, so the back can pass through to the other cabinet. Extend one of the backs so that it would be the correct size. If you delete the other back, then you'll lose the dado, so don't delete it. That second back will show up on the cut and cost lists. You can eliminate it by filtering it from your nest or minimize it by using an inset for that back so it is extremely small. The good thing is that the dado and tenon should match without drawing it and using constraints.
As in various scenarios, if you change the size of either cabinet, then you may need to adjust the length of the back. If the height of both cabinets are changed, then both backs should adjust, as well as any changes in cabinet depth. If you inset the back on one, then you need to inset by the same amount on the other.
Dennis
Dennis, can you post an example cab? I'm just trying to wrap my head around this topic. :?:
Dennis Englert
I've attached an assembly of two cabinets, that I just roughed up to see if my theory would work.
Dennis
Stretched Back 2 Cabinets.esa
(368.02 KiB) Downloaded 2280 times
I get it. Thanks Dennis.
