RTA/Lock Dado Not Showing
TonyGiunta
Company Name: ToSa Design
Postby TonyGiunta » Wed, Mar 06 2013, 12:08PM
All of a sudden, I can't get the fastener holes to show up. If a take a standard detached toe and do a joint global to either RTA or Lock Dado, they don't show up in the cabinet editor, nor when I nest it. But on Cab Buy list the RTA fitting count is there. Never had this problem before and don't know what could be causing this. I have restarted eCab and still have problem. Any suggestions? Thanks.
Rick Deskins
Company Name: Thermwood
Re: RTA/Lock Dado Not Showing
Postby Rick Deskins » Wed, Mar 06 2013, 1:24PM
Reapply the KD/RTA hole pattern to the cabinet using the KD/RTA tab in the item window
Rick Deskins
eCabinet Systems Programmer
TonyGiunta
Postby TonyGiunta » Wed, Mar 06 2013, 2:05PM
Thanks Rick, that seemed to do the trick when I also assigned a hole pattern. But I never had to do that before. I could just load a standard cab and choose which joint. Why isn't the hole pattern sticking to the RTA fastener for standard menu joints?
TonyGiunta
Postby TonyGiunta » Wed, Mar 06 2013, 2:27PM
OK, It seems like just the detached toe kick standard cabinet does not have a hole pattern pre-assigned in eCab. It used to I'm sure. How can this be changed since you can't overwrite a cab in the standard directory with any changes (i.e.hole pattern)?
Rick Deskins
Postby Rick Deskins » Wed, Mar 06 2013, 4:01PM
Save then cabinet in a different folder, then copy then cabinet file to the Standard Cabinets folder via Windows file explorer
Rick Deskins
TonyGiunta
Postby TonyGiunta » Wed, Mar 06 2013, 4:46PM
OK, Thanks Rick. Can't imagine how that changed in the 1st place.
Users browsing this forum: No registered users and 12 guests
