DRAWER BOX DEPTH
sheldon wohlgemuth
Company Name: silverpine cabinets
DRAWER BOX DEPTH
Post by sheldon wohlgemuth »
Any ideas for me our slides require 540, 490, 440 lengths. With our regular drawers I set the depth increment to 50mm and designing the drawer I did a 10mm back inset so it automatically adjusts with depth change. We are using the dovetails some, on these I can't seem to do a back inset. Is there any other way to trick it?
Re: DRAWER BOX DEPTH
Hey Sheldon, if you add the 10mm inset to the sides, bottom, and back you should be able to get the results that you're after.
Std_Dovetail Dbx -slide in btm test.hsf
(402.02 KiB) Downloaded 1085 times
