Modify Textures in custom lay out
Scott Marshburn
Postby Scott Marshburn » Sun, Mar 24 2013, 7:13PM
This feature is a great improvement .But it would be nice if we could select individual cabinets and or display objects to edit each one .For example we have a job that requires the sink base to be stained and all of the other cabinets to be painted.We are using the same materials for all of the cabinets in this job. If we could select the sink base and select the texture for that cabinet. Then select the other cabinets and select the texture for those cabinets.Would something like this be possable?
Jon Dieterlen
Re: Modify Textures in custom lay out
Postby Jon Dieterlen » Sun, Mar 24 2013, 7:41PM
+1 on the selecting individual cabinets to modify textures. Most jobs we do have a different finish for the island. I have been changing materials for the items that need the different finish, then you can modify the texture for that material.
As a side note, I would rather see see some other improvements like locking opening sizes, automatic dimensioning in the LDE, and some improved capabilities in the build in house 5 piece door areas. Anything that decreases the time required to get the job into production.
Jon
Postby Rick Palechuk » Mon, Mar 25 2013, 1:05AM
When in Custom Layout select Elevation Mode, from there you can select individual cabinets, then right click and select Change Materials.
Scott Marshburn
Postby Scott Marshburn » Mon, Mar 25 2013, 5:38AM
Hi Rick I know that you can change materials on individual cabinets in custom layout. I am talking about modifying the existing materials texture on a single cabinet without having to change the material.Or change the texture on all cabinets
Users browsing this forum: No registered users and 10 guests
