Vacuum Pump for my C53
Gavin Armstrong
Company Name: Armstrong Engineering
Country: UNITED KINGDOM
Postby Gavin Armstrong » Sat, Nov 02 2013, 4:41AM
Hi, I am looking to fit a vacuum pump to my C53. It has the vacuum bed fitted but I do not have the pump.
Bed size is 5ft by 10ft
What type and size of pump is recommended for this machine.
Many thanks Gavin
Gerry A Brown
Re: Vacuum Pump for my C53
Postby Gerry A Brown » Wed, Nov 06 2013, 9:52AM
Hi Gavin,
Our bed is 5' X 12' and we use a pair of Busch 10 hp pumps. We have a vacuum gauge installed on the line to the machine bed so we can watch the vacuum level & run the second pump if necessary. We do run both pumps if we are cutting a lot of small parts. You need a pump that will pull a good amount of vacuum but also a large cfm as there is a lot of bleed through. You should mask the unused portion of your table to minimize the bleed through.
HTH
Gerry
Will Williamson
Postby Will Williamson » Wed, Nov 06 2013, 10:37AM
I am still running the 18 HP Becker that Thermwood supplied with my CS45 5' x 10' seven years ago. Never had any problems in 7 years, not one
Will
http://www.willmade.com
Gerry A Brown
Postby Gerry A Brown » Mon, Nov 11 2013, 1:19PM
Will,
What is the model number of your pump. We bought our router used and it did not come with a pump so I don't know about the Becker line.
Gerry
Will Williamson
Postby Will Williamson » Tue, Nov 12 2013, 8:01PM
It is a model 400.
Will
Brian Kutzke
Company Name: Westin-Nielsen
Postby Brian Kutzke » Thu, Dec 19 2013, 7:46PM
We have been looking at purchasing another pump as well. What is a good CFM combination? Our current small pump only pulls 56 CFM...
Will Williamson
Postby Will Williamson » Thu, Dec 19 2013, 7:58PM
I think the model 400 produces 400 cubic meters per hour. It is designed to pull a constant 22 inches of vacuum
Will
Neville Bastian
Postby Neville Bastian » Wed, Mar 05 2014, 8:22PM
We run two 250cfm pumps. I was wondering if anyone has the CN software switch from one pump to two pumps when the parts are released? Not sure if this is built into the Thermwood controls or a add on.
We find its the final cut into the spoil sheet when you have smaller parts that the second pump is required. This would save me power and wear and tear on the second pump.
I have investaged the inverter option but last time I costed it is about 10k and the payback period was too long.
Regards
Neville
Neville Australia
