Display cubes and part editor
Chris B Campbell
Post by Chris B Campbell »
Hey All,
Need some help I am trying to build a hood, three of the sides are angled (Front along with right & Left sides) . I can only display one side in the part editor to cut away the portion I need, for instance the front, I cannot however rotate the cube in the part editor so as to remove the other two sides.
Any help??
Chris
Scott Marshburn
Re: Display cubes and part editor
Post by Scott Marshburn »
You will have to make a cutter and use it to cut the other 2 sides
Chris B Campbell
Thanks Scott,
Not gonna' even ask how, but I do appreciate the response :-)
have a great day,
Chris
Scott Marshburn
Can you post any specs. On the unit i.e.. Angles and dimensions etc.
A drawing would be great.
Chris,
Here is a look at the tool I used to cut the skin for the heed below. It cuts both sides to leave a 1/4" skin.
