Combining cabinets
Ron Sloan
Company Name: Wine Country Custom Carving
Combining cabinets
Postby Ron Sloan » Sun, Mar 09 2014, 1:15PM
A couple of quick questions:
The libraries from e-cab’s all have modular units – one full cabinet for each unit – meaning if I have a 30” cab with 2 doors and 2 drawers next to a 30” cab with all drawers, instead of using a 60” long bottom and a shared partition, I am supposed to make two complete independent units? If so it is a little wasteful
Also, my renderings all seem to look like the sheet stock is actually made up of board stock - i.e. they appear to be slats joined at an odd angle. It seems to do this no matter what material I assign. Is there a simple setting I'm missing? I've attached an image showing what I mean.
Ron
jason galbraith
Country: AUSTRALIA
Re: Combining cabinets
Postby jason galbraith » Sun, Mar 09 2014, 3:50PM
You can make it however you want. However, two units is easier to assemble, easier to transport and deliver, easier to price.
www.eastcoastultimate.com.au
Scott G Vaal
Postby Scott G Vaal » Mon, Mar 10 2014, 10:12AM
Ron Sloan wrote:Also, my renderings all seem to look like the sheet stock is actually made up of board stock - i.e. they appear to be slats joined at an odd angle. It seems to do this no matter what material I assign. Is there a simple setting I'm missing? I've attached an image showing what I mean.
Ron
Ron,
Does the same look happen if you load one of the cabinets from the Standard Cabinets directory?
Ron Sloan
Postby Ron Sloan » Mon, Mar 10 2014, 12:19PM
Thanks for the replies.
Scott - yes, cabinets loaded directly from the standard library also exhibit this look.
Scott G Vaal
Postby Scott G Vaal » Mon, Mar 10 2014, 1:07PM
Ron Sloan wrote:Thanks for the replies.
Ron,
Would you please save a cabinet with one or more of your own materials/texture images and post it here. I will load it on my system and see if I get the same result. Thanks.
Ron Sloan
Postby Ron Sloan » Mon, Mar 10 2014, 2:02PM
Scott,
The same phenomenon appears in virtually all the editor. Attached is a Std Base Frameless Cabinet, with default generic 3/4" sheet, and I changed the top material image. Hope this helps.
Ron
StdBase.zip
(68.68 KiB) Downloaded 70 times
Scott G Vaal
Postby Scott G Vaal » Tue, Mar 11 2014, 9:04AM
Ron,
We cannot reproduce this issue here. What graphics card do you have in your PC? Please ensure you have the newest available driver installed for it.
Ron Sloan
Postby Ron Sloan » Tue, Mar 11 2014, 1:11PM
Scott,
I have a Radeon X800 series card, with the latest available drivers for Windows 7 Ultimate. If I'm correct, it seems to have started after I installed the materials library. I just tried changing the material color for Generic 3/4" material to sr-wood f-c White Birch. While it looks better, you can still see the same thing happening. Looking closely at the endgrain on the side panel, the garin appears to be slanted at ~45 degree angle. With this material, at least the grooves don't show up. Don't know if any of this info helps, but thought it couldn't hurt!
Edit: digging a little deeper, it seems the grooves show on almost any material, except those in the Formica, Stone, Marble and SR-Wood categories. Those materials look fine, except for the angled end grain as shown, which is not a big deal.
Thanks for looking into this for me!
Ron
Users browsing this forum: No registered users and 13 guests
