Furniture Carving RP-FR-FN0001
Moderators: Jason Susnjara, Larry Epplin, Clint Buechlein
Marius Gouws
Company Name: Plett Roofing
Country: SOUTH AFRICA
Postby Marius Gouws » Tue, May 06 2014, 10:30AM
Good afternoon.
Try to do this carving on our machine, but it run dead slow (feed speeds) it will take a week for it to complete. My feed rate override is set at 100%. It is like there is a G809 or G810 in there some where. The Feedprogram is set at 200. I suppose that is iches.
Any help or advise?
Marius Gouws
Re: Furniture Carving RP-FR-FN0001
Postby Marius Gouws » Fri, May 09 2014, 5:59AM
So there is no explanation for it, or something that I can do about it? They should take it out of the carving library then so someone does not have to go red face back to the client and tell them I can not machine it.
Cheers
Brad McIntosh
Company Name: CNC Automation
Postby Brad McIntosh » Fri, May 09 2014, 8:19AM
Marius,
As has been mentioned on these forums previously - they are not the PRIMARY SUPPORT CHANNEL for Thermwood Corporation.
I suggest that you submit any serious issues that you may have directly to Thermwood via the email addresses below:
eCabinets Systems Support: cabinets@thermwood.com
Control Nesting and General Programing Support: program@thermwood.com
Machine Related Electro-Mechanical Problems: service@thermwood.com
It does sound like the carving programs are using imperial/inch units and there is probably no G70s to tell it otherwise. You will have to contact Thermwood to see if they can help you rectify this. program@thermwood.com would probably be your best avenue at this time.
Good luck...
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Users browsing this forum: No registered users and 12 guests
