KD fasteners and tooling
Will Williamson
Postby Will Williamson » Thu, Jul 10 2014, 11:42AM
What brand and model of KD fasteners do you like to use ? What special tooling is used? I do not have a drill block.
How does this method KD fastener, compare to blind dado and pocket screws, for shipping to the consumer for final assembly?
Will
http://www.willmade.com
Company Name: Halls Edge Inc
Re: KD fasteners and tooling
Postby Josh Rayburn » Thu, Jul 10 2014, 11:51AM
Will,
We use Hafele Rafix fasteners.
All the machining can be done with a standard 5mm upshear / drill, and interpolation for the larger hole with any tool you like (we use the 8mm upshear). No drill block required.
Hope this helps,
Will Williamson
Postby Will Williamson » Thu, Jul 10 2014, 12:38PM
Hi Josh
Thank You. Is that the default KD fastener that come with the Ecabinet Software?
Will
Gerry A Brown
Postby Gerry A Brown » Fri, Jul 11 2014, 7:16AM
We use the Rafix also. There are 2 versions 1 sits 1mm proud of the surface & the other will go flush. You need a 20mm drill bit that cuts a chamfer for the flush version. We use a 20mm drill bit for the type that sits proud. We don't use them on a lot of cabinets but for some applications they are the answer.
Gerry
Postby Josh Rayburn » Fri, Jul 11 2014, 7:52AM
We don't use the flush connectors at all. The chamfer would be a problem in machining - it would likely warrant a custom tool to do those drill operations in one drop if there were enough of them. Just my opinion
Postby Forrest Chapman » Fri, Jul 11 2014, 9:00AM
Josh, Hafele sells a bit with the chamfer edge. The bit plunges once and is done. You can use the same bit for both types of cams. Its the only tool I've used for 10 years.
Will Williamson
Postby Will Williamson » Fri, Jul 11 2014, 9:14AM
What is the application for the flush mount as compared to the one that protrude?
Will
Gerry A Brown
Postby Gerry A Brown » Fri, Jul 11 2014, 9:21AM
Will Williamson wrote:What is the application for the flush mount as compared to the one that protrude?
I am sure there are other situations that require them but for us it would be, drawers so the drawer face fits flush and cabinets that need to sit flush on another cabinet or have another cabinet or counter sit flush on them.
Gerry
Postby Josh Rayburn » Fri, Jul 11 2014, 12:14PM
Forrest, thank you I never had a need for it but it's great to know the bit is readily available if we come across a situation that warrants it!
Gerry, what thickness drawer material are you using?
Gerry A Brown
Postby Gerry A Brown » Fri, Jul 11 2014, 3:47PM
Josh Rayburn wrote:Forrest, thank you I never had a need for it but it's great to know the bit is readily available if we come across a situation that warrants it!
We use 5/8" melamine or baltic birch.
Gerry
Postby Josh Rayburn » Mon, Jul 14 2014, 7:07AM
Gerry, you might need the minifix instead, I think the "regular" rafix connectors might be only for 19mm material, but you would have to check that out if you haven't already. I have had success with both fasteners.
Hope this helps,
Postby Forrest Chapman » Mon, Jul 14 2014, 11:15AM
You can buy Rafix for both 19mm and 16mm material. The flush mount is for the exact scenario of adjacent mounting but also because it is less visible and even excepts a thin cap to hide it. The bit I'm using works extremely well and last a long time but you will need to set the RPMs no higher than 10k and plunge at 100 IPM. The max RPMs from the manufacturer I believe is 3800 RPM but I've used 10k for the last 10 years on the same bit. Its hard to put a number on the amount of holes I've drilled with this same bit but I'm sure its over 50k.
Will Williamson
Postby Will Williamson » Mon, Jul 14 2014, 11:29AM
So now are you using the Kd fasteners with lock dado or blind dado? or ?
After 7 years, I have still not cut a set of cabinets.
Will
Gerry A Brown
Postby Gerry A Brown » Tue, Jul 15 2014, 7:59AM
Hi Josh,
We have used them in the past but I just looked for the part online & I see the flush version in 16mm has been discontinued. I guess I will need to find an alternative for the 16mm. I'll give the minifix a look.
We mostly use them on 19mm lock dado closet parts so it is not something I do every day.
Gerry
Postby Forrest Chapman » Tue, Jul 15 2014, 9:05AM
Hafele still has them in beige Item #: 263.50.403.
The "Minifix" requires horizontal boring. It is used commonly in office furniture and crappy vanities from a big box store.
I have machined parts for the Rafix on a weekly basis for 10 years now. Closet parts are almost always cams only joinery. Cabinets can be either the cam lock or lock dado joinery. As of late almost all of the cabinet parts have been in the newer pocket screw joinery.
Users browsing this forum: Bing [Bot] and 3 guests
