cabinet dimension locks and the metric system
Mark Hesketh
Company Name: Paris Kitchens
Postby Mark Hesketh » Tue, Jan 13 2015, 3:17PM
Is there a known issue that prevents locking a cabinet to a set size when using metric, or am I approaching this in the wrong way?
I am trying to demonstrate how we can take a dxf of an existing part (pre-ecabs) and apply it to a gable in order to quickly produce exactly what they are used to seeing. I have done this with the part editor, but wanted to lock the dimensions so that nobody could try to resize and screw-up the hole locations since I don't want to spend the time constraining everything. I have set the lock dimension so that the mins and maxs are equal (height=768mm, depth=300mm, width=16mm). I keep getting an error message that the min depth must be equal to or smaller than current cabinet depth... but it is. If I adjust the min number below what I want it to be, it then jumps to the same error message for the width.
Is this just because I am using metric, or can the min/max dimensions not be equal?
Scott G Vaal
Re: cabinet dimension locks and the metric system
Postby Scott G Vaal » Tue, Jan 13 2015, 5:17PM
Mark,
You are doing everything correctly. It does appears to be an issue with metric. I have it listed and we will resolved it as soon as possible. Thanks for bringing it to our attention.
Mark Hesketh
Postby Mark Hesketh » Wed, Jan 14 2015, 7:06AM
No Problem. Thanks Scott
Users browsing this forum: No registered users and 34 guests
