Can't find approapriate tool ?
Dale Wills
Company Name: none
Country: AUSTRALIA
Postby Dale Wills » Sun, Jan 18 2015, 12:08AM
Hi all,
I'm trying to machine out some material that has 54.4mm wide dado's to accommodation for 54mm thick shelves. When writing the code I'm getting this error -
"There was a problem finding an appropriate tool for an operation. Please check the CNC file for the problem."
Now, within the CNC code I found the following error message which is associated with performing the routing operation for the dado.
"Error: tool size between 54.401 and 27.200 not set up in tooling"
Within the tooling settings of control nest we have a 12.7mm cutter assigned to perform Rout/Dado operations and has a '38mm max interpolation diameter'
What am I missing here. This 12.7mm cutter should perform this operation shouldn't it?
Thanks in advance,
Dale
Re: Can't find approapriate tool ?
Postby Kerry Fullington » Sun, Jan 18 2015, 9:10AM
Dale,
To cut the 54.4mm dado your tool will need to be at least half that diameter, 27.2mm.
I think the interpolation is just for pocket operations not dados.
A dado is just a four sided box that gets cut so the tool must be half the width to clean everything out.
Dale Wills
Company Name: none
Country: AUSTRALIA
Postby Dale Wills » Sun, Jan 18 2015, 5:26PM
Thanks Kerry,
I knew there was some rule there governing dados but couldn't quite remember. I have been out of the game too long now.
Perhaps this is something that could be altered in control nest. It seems a tad restrictive on the machines ability to not be able to perform this operation given that the 12.7mm cutter could perform this with 1 extra pass. Basically it means having to buy a new larger diameter cutter for those rare occasions where you need to machine large width dados.
I will get by this by just creating some dummy shelves in ecabs and leave a small gap between the shelves to fudge a 54mm wide dado. Any other suggestions on how to tackle this muchly appreciated.
Dale
Postby Kerry Fullington » Sun, Jan 18 2015, 6:50PM
Dale,
You could create the dados in the part editor manually and they will then be considered a pocket cut and you can then use your smaller tool as the pocket tool.
Dale Wills
Company Name: none
Country: AUSTRALIA
Postby Dale Wills » Sun, Jan 18 2015, 7:44PM
awesome...thanks Kerry
Postby Forrest Chapman » Wed, Jan 21 2015, 10:36AM
Guys, control nest 5.80 added the ability to pocket dado's that were to large for the tool. What version are you on Dale?
Scott G Vaal
Postby Scott G Vaal » Wed, Jan 21 2015, 10:48AM
Gentlemen,
As Forrest just mentioned, the latest Control Nesting (5.80+) will now attempt to pocket dados when an acceptable size range dado tool is not found. It's a great new feature, so do not do extra work making part editor dados just to achieve this. Let us know if you run into any issues.
