Slide Holes Not Visible
Vince Lisanti
Post by Vince Lisanti »
BRH_24D_1 DRW.jpg (16.12 KiB) Viewed 4663 times
BRH_24D_1 DRW.hsf
(1.75 MiB) Downloaded 686 times
I cannot get drawer slide holes to be visible in the upper partitions in this cabinet. They show up in the nest so I am assuming they would be cut, but I want to make sure and would also like to know if they are visible for anyone else.
Dell Precision M4800
32 GB RAM
NVIDIA Quadro K 2100M
Scott G Vaal
Re: Slide Holes Not Visible
Post by Scott G Vaal »
Vince,
Your partitions are positioned past the inside edge of your left and right face frame stiles. This is because the 0.0156" (1/64th) scribe that you have applied plus 2 times the material thickness .75" (3/4") is wider than your FF stiles (overhangs the inside edge by .0156"). Since slide patterns are designed to position from the inside edge of the FF stiles, your scenario is causing the pattern to get buried into the partition. Do you need this small scribe?
Vince Lisanti
Thanks for the quick response Scott. That answers my question. I will do away with the 1/64" scribe on these cabinets.
Thanks again.
32 GB RAM
