Control Nesting issue
Neal Stephenson
Postby Neal Stephenson » Mon, May 18 2015, 6:45AM
Hi All,
I am suddenly getting an error when nesting.
Once the file has been selected, I select Nest X or Y,
then a "RNest" error pops up saying:
Unreconized database format: \Rolling Nest\result.mdb
Anyone seen this before?
and any ideas on what can be done to fix it?
Thanks in advance,
Neal.
NEAL STEPHENSON
Neal Stephenson
Re: Control Nesting issue
Postby Neal Stephenson » Mon, May 18 2015, 8:05AM
If it makes any difference we running Version 6. No issues and then suddenly...
NEAL STEPHENSON
Brad McIntosh
Company Name: CNC Automation
Postby Brad McIntosh » Mon, May 18 2015, 10:32PM
Neal,
With the latest versions of eCabinet Systems (currently Version 6 Build 17) you need be running with the latest version of Control Nesting that your generation of THM controller will allow. Depending on your THM version that will be either 6.84 or 5.59 Patch 3.
The 5.59 Patch 3 version is for those machines that do not meet the latest requirements for the releases from 5.60 onwards.
As of version 5.60 and on you MUST have Profile Modeler installed to update Control Nesting. You must also have THM (Windows 2000 system version - 5.05, Build 9 or higher) OR (Windows XP Pro system version - 6.1.0.4 or higher) OR (Windows 7 QCore) installed.
If you system does not meet the minimums for the latest versions of Control Nesting, you can request a retro from Thermwood. A retro may consist of simply a software update to the last release of the 5.05 Windows 2000 based control software or you can bring things right up to a Q-Core retro that will upgrade not only the software to the latest 9.x, but also the required supporting computer hardware. Contact Thermwood's Retro Group for more information. (http://www2.thermwood.com/eCabinetReq.n ... 4?OpenForm)
Review the Control Nesting update page for more information.
http://www.thermwood.com/updates_control_nesting.htm
Hope this helps...
