when adding in corner doors (double left or right) i wanting to be able to use a hole pattern to put hinges and hinge plates on the opening door. the program as far as i understand can only support the adjustment of hinge positions on the first door only and the second door has to be done manually. we set our hinges up a little higher than the cabinet hinge so we are adding the holes manually. is there a way that this goal can be acheived or such feature be added to the next update possibly?
add double left - double right door
- Country: AUSTRALIA
