Truncated Layer Names on DXF
Stuart Douglas
Postby Stuart Douglas » Tue, Jun 23 2015, 1:37PM
Iv'e run into a problem involving the layer names in my dxf file(s). It seems that the R12 DXF only supports up to 26 characters in the layer names in the file. I have exceeded that amount and it seems to be causing a CN error where it thinks the thickness required is 0.000. Has anyone else run into (and solved) this problem? Are there some syntax shortcuts that I could use to shorten the layer name that the control would still recognize? It looks like I'd have to hold my layer dimensions to only 1 or 2 digits to get this to work, and it could get tooling confused that has been resharpened when the tool calls are executed.
Jeremy Schiffer
Re: Truncated Layer Names on DXF
Postby Jeremy Schiffer » Tue, Jun 23 2015, 3:00PM
Are you using the (relatively new) Tool Names to call the tools, or are you specifying the diameter in the layer name? This not only will save you a few characters, it also saves the headache of picking up the wrong tool because it is the same diameter as the tool you intended to pick up.
In case, I've attached a screenshot showing layer names with Tool Names in them. They're encased in brackets, e.g. [3185].
Intel Core i7-5820 3.3GHz, 16GB RAM, NVidia Quadro K2200 4GB, Windows 8.1 Pro 64 bit
Jeremy Schiffer
Postby Jeremy Schiffer » Tue, Jun 23 2015, 3:06PM
Oh well, for some reason the screenshot won't upload. Read the DXF section of the manual though, it explains it.
Stuart Douglas
Postby Stuart Douglas » Wed, Jun 24 2015, 5:48AM
Jeremy Schiffer wrote:Oh well, for some reason the screenshot won't upload. Read the DXF section of the manual though, it explains it.
"new?" My Manual is from last year and yes we call out the diameter of the tooling in the layer name. Is there a better way?
Do you have a template file (like DXFLAYERS.dxf) that you could share, or is available somewhere? I'm using the one from the helpful files folder provided in the training when i went to Dale, IN.
Company Name: Halls Edge Inc
Postby Josh Rayburn » Wed, Jun 24 2015, 6:28AM
