Zach Froble
Posts: 171 Joined: Tue, Jun 21 2005, 3:23PM
Post
by Zach Froble » Wed, Sep 23 2015, 11:47AM
I am trying to import a batch list of panels from open office saved in xls format. I followed the help file, but still can't get it to work. Any hints or tricks to get this to work.
Zach
STOUT,VAUN DOOR PANEL TEST.xls
Excel Batch Import (8.5 KiB) Downloaded 3136 times
Lyndan Designs
Machining and CAD Services
Scott G Vaal
Posts: 1740 Joined: Tue, May 17 2005, 12:44PM
Post
by Scott G Vaal » Wed, Sep 23 2015, 12:58PM
Zach,
It works correctly for me if I create the directory named LD ACCESSORIES and save a cabinet named SKIN into it. Make sure your directory and cab name match (unmatched spellings or spaces will cause failure). Do you get any error message when you run it?
Zach Froble
Post
by Zach Froble » Wed, Sep 23 2015, 1:00PM
No error message nothing happens. I will double check the spelling and directories.
Zach
Lyndan Designs
Zach Froble
Post
by Zach Froble » Wed, Sep 23 2015, 4:59PM
Scott,
I tried renaming the directories and cabinet name and still nothing. I am not getting any errors. Is there anything else that could be causing this?
Zach
Lyndan Designs
Rick Deskins
Posts: 858 Joined: Tue, May 17 2005, 12:47PM
Company Name: Thermwood
Post
by Rick Deskins » Wed, Sep 23 2015, 8:07PM
You mentioned you were using open office. If you do not have excel install on your pc, you need to install excel viewer. It puts the proper dll on your pc that will allow for excel imports.
http://www.microsoft.com/en-us/download ... aspx?id=10
Rick Deskins
Zach Froble
Post
by Zach Froble » Fri, Sep 25 2015, 7:53AM
Rick,
That did it.
Thank you,
Zach
Lyndan Designs
Zach Froble
Post
by Zach Froble » Wed, Sep 30 2015, 2:31PM
Rick,
I went to import a batch today and now I am getting nothing again. It worked after I installed the excel viewer, but now nothing.
Any insight to why this is causing so many problems. Should I get a copy of excel and not use open office?
Zach
Lyndan Designs
Rick Deskins
Post
by Rick Deskins » Wed, Sep 30 2015, 7:15PM
Can you post your excel file you are trying to import?
Rick Deskins
Zach Froble
Post
by Zach Froble » Thu, Oct 01 2015, 7:51AM
Here is the file.
DOOR PANEL TEST.xls
(10.5 KiB) Downloaded 3126 times
Lyndan Designs
Rick Deskins
Post
by Rick Deskins » Thu, Oct 01 2015, 7:57AM
You have a space after the directory name. May try removing the trailing space.
Rick Deskins
Zach Froble
Post
by Zach Froble » Thu, Oct 01 2015, 8:22AM
Rick,
I have tried renaming with and with out spaces still nothing is working. I have double checked spelling over and over, but still can't get it to work.
Lyndan Designs
Rick Deskins
Post
by Rick Deskins » Thu, Oct 01 2015, 2:13PM
Does this work for you?
DOOR PANEL TEST.xls
(22.5 KiB) Downloaded 3123 times
Rick Deskins
Zach Froble
Post
by Zach Froble » Thu, Oct 01 2015, 2:47PM
Rick,
This time it gave me an error. "Error loading row 0 of c;\users\zach\downloads\door panel test.xls. Failed to load BEP.
Lyndan Designs
Zach Froble
Post
by Zach Froble » Thu, Oct 01 2015, 3:12PM
Rick,
I double checked the file you posted and realized that I had renamed the LD ACCESSORIES directory while playing around and it does work now.
Lyndan Designs
Rick Deskins
Post
by Rick Deskins » Thu, Oct 01 2015, 8:46PM
Glad to hear that it worked. All I did to your xls file is remove the space at the end of "LD ACCESSORIES".
Rick Deskins
