Cnc is loading jobs slow and slow in general
Chris Armstrong
Country: AUSTRALIA
Post by Chris Armstrong »
we have a Thermwood MTR36004 3 axis machine.
Over the years the machine has been gradually getting slower and slower, for example when i go in to the control nesting it sometimes takes a while for it to load up and then when we go to load a job that also takes some time to load and nest. a simple turn on off, does seem to affect it. when it is cutting it is fine, its just slow on loading jobs, nesting and opening control nesting.
i have removed cnc files and twd files from the machine to clear up space to hopefully give it some speed.
my first thought is if its not the files could it be the ram on its way out? or the ecabinets updates require more ram to read the updated cabinets?
although the machine has a fair amount of ram and unsure if the motherboard would even support more.
do you guys know what else i could be missing? or if there is something else that could be slowing it down?
thanks
Chris Armstrong
Country: AUSTRALIA
Re: Cnc is loading jobs slow and slow in general
disk defragment or disk cleanup cleaned up alot of files but still hasnt really made much of a difference to the speed of loading.
Daniel Odom
Post by Daniel Odom »
Try breaking up your jobs into smaller batches. Also, clear the load list, close the nesting and then open it again between batches. That seems to help me anyhow.
Chris Armstrong
Country: AUSTRALIA
Thanks daniel i will give that a shot, just a tad unsure on what you mean by close the nesting and then open it again between batches do you mean clear what has been loaded?
thanks for the ideas i will give that a try
Daniel Odom
Yeah, I clear the list, hit ok, then exit out of nesting to the main thm screen and then open up nesting and load a new job.
Will Williamson
Post by Will Williamson »
So, how much ram do you have?
Will
http://www.willmade.com
Chris Armstrong
Country: AUSTRALIA
hi william, we are using 1Gb of ram
Will Williamson
What operation system? Can you bump it up to at least 4 gig. That would make a big improvement.
Will
Post by Forrest Chapman »
Chris, buy THM desktop for your computer and you will never look back. I think its $1k to start with and $200 a year renewal. I would assume you have a fairly robust computer for running ecabs or other design software so not only will it free up your router to just run code but control nest will process much faster on your computer.
Chris Armstrong
Country: AUSTRALIA
hi william , we are using windows xp so im not sure if that allows for a higher ram to be used? im unfamiliar with xp
thanks for the idea Forrest, but at this time its not practical for us to do it that way.
Will Williamson
You can add up to 4 gig of ram. it will make a big difference. newegg.com
Will
Chris Armstrong
Country: AUSTRALIA
thanks will
i will organize them and i will report back when they are installed
thanks again
chris
Chris Armstrong
Country: AUSTRALIA
[i have installed new ram they are 2 sticks of 2gb, but on startup makes a continuous beep and does not boot up. which means either the ram is faulty or the mother board doesnt support 2gb sticks
do you guys know if this is the case or?
Will Williamson
You have to replace it with the same style that the machine came with. I called thermwood to find what was in mine originally.
Mine was DDR400 consisting of 4 (1) gig sticks
Will
Chris Armstrong
Country: AUSTRALIA
yeah i read the ram and ours is DDR400 too, but the motherboard must not support 2gb ram sticks, thanks for your help will see what i can find in 1 gig
