"Duplicate" DXF entities
Jeremy Schiffer
Postby Jeremy Schiffer » Thu, Nov 12 2015, 1:22PM
I'm having trouble getting some DXF files to work properly, and I've narrowed it down to the fact that CN is apparently seeing NEARLY coincident lines on separate layers as duplicates. They are separated by .01mm, so yeah, they're close, but I would think in the computer world, .01mm may as well be 1 mile. It either is, or is not, in the exact same location. At any rate, does anyone know what the tolerance is, and at what point CN stops seeing these entities as "duplicate"?
Intel Core i7-5820 3.3GHz, 16GB RAM, NVidia Quadro K2200 4GB, Windows 8.1 Pro 64 bit
Jeremy Schiffer
Re: "Duplicate" DXF entities
Postby Jeremy Schiffer » Thu, Nov 12 2015, 1:28PM
Just to clarify, what I basically need is two tools to follow the same line. Knowing there can't be duplicate entities, I separated the lines by .01mm. The lines are on separate layers. Does anyone have any tricks up their sleeve to accomplish this? It's a very common occurrence. I could make one a Centerline, and another one a Chaincompin, but then I lose the ability to have the machine apply radius comp. :?
Brad McIntosh
Company Name: CNC Automation
Postby Brad McIntosh » Thu, Nov 12 2015, 1:51PM
Jeremy,
Well, 0.01mm is just under 0.0004". Perhaps you can try 0.03mm which would would result in an approximately 0.0012" "shift" - something that Control Nesting (CN) may better differentiate AND is really not that much of a variance when machining.
Note: I have not tried this myself, so...
Brad McIntosh
Postby Brad McIntosh » Thu, Nov 12 2015, 1:58PM
Jeremy,
Can you post your DXF?
Jeremy Schiffer
Postby Jeremy Schiffer » Thu, Nov 12 2015, 2:32PM
I changed it to .1mm and it works, so it is somewhere between .01 and .1mm. One of these days I'll figure out the exact number, but in this instance I was able to work around it. .1mm is certainly not critical on the MDF doors this is for, but on some things, .1mm isn't an acceptable variance. I'll attach the DXF. (change from TXT to DXF of course)
door test.TXT
(55.36 KiB) Downloaded 157 times
Larry Epplin
Postby Larry Epplin » Thu, Nov 12 2015, 4:11PM
Glad you were able to accomplish a work around. The tolerance in metric is 0.0254. You bring up a valid argument. We will work on getting the duplicate elimination to be layer specific.
Jeremy Schiffer
Postby Jeremy Schiffer » Thu, Nov 12 2015, 5:05PM
Thanks Larry, that would be awesome!
Jeremy Schiffer
Postby Jeremy Schiffer » Fri, Jan 15 2016, 8:51AM
I immediately had the opportunity to utilize the new feature of allowing duplicate entities, it worked great. Many thanks!
Larry Epplin
Postby Larry Epplin » Fri, Jan 15 2016, 9:05AM
Great!
Users browsing this forum: Bing [Bot] and 1 guest
