Sloped vent hood top
t w fortier
Company Name: linus fortier llc
Postby t w fortier » Mon, Dec 21 2015, 3:55AM
Hi...
Is there a way to slope the top of a vent hood in ecabinet or door ?
tony
tim lucas
Re: Sloped vent hood top
Postby tim lucas » Mon, Dec 21 2015, 8:04PM
t w fortier wrote:Hi...
tony
Is this what you mean?
W3612 Vent Hood.jpg (10.51 KiB) Viewed 3429 times
or
Hood 32.jpg (9.48 KiB) Viewed 3429 times
Tim
HP Desktop
i5 2400 @ 3.10 GHz
8.0 G Ram
Win 7 Pro
Nvidia Quadro NVS 290
Blessed is the man who finds wisdom,
the man who gains understanding.
t w fortier
Postby t w fortier » Mon, Dec 21 2015, 11:44PM
Tim, Hood 32.jpg is what I mean.
tony
tim lucas
Postby tim lucas » Tue, Dec 22 2015, 7:30AM
Here is the file for it
Hood 32.hsf
(198.02 KiB) Downloaded 158 times
I just used the rotate tool and part editor to create the look of the hood - I did not cut the hood out from this file
Tim
HP Desktop
i5 2400 @ 3.10 GHz
8.0 G Ram
Win 7 Pro
t w fortier
Postby t w fortier » Fri, Dec 25 2015, 11:53PM
Tin thanks for the reply, I down loaded your file and got 4x8 display board, ??
I up loaded my vent hood, it is very crude.
The only way could make it was to use two cabs but I could not find a way to associate the two cabs as one. Can you or someone else improve on the file I uploaded?
tony
6 VENT HOOD 3.esa
(862.02 KiB) Downloaded 150 times
tim lucas
Postby tim lucas » Sat, Dec 26 2015, 8:30AM
Tony
You are correct, you can not save 2 cabinets as 1 but your assembly will work just like a cabinet in your room
As I said I did not cut my hood it was for show only. I looked at yours and if that is what you need then it is just right.
If you are planning to cut it out and build it I might suggest changing the cabinets to frameless and letting your doors cover to the edges.
You are on the right path :D
Tim
HP Desktop
i5 2400 @ 3.10 GHz
8.0 G Ram
Win 7 Pro
Users browsing this forum: Google [Bot] and 9 guests
