Wasteboard minimum thickness
Jeremy Schiffer
Postby Jeremy Schiffer » Thu, Jan 21 2016, 11:34AM
Using THM 9.1.2, the flycut program, which is amazing in every other respect, is telling me the minimum thickness allowed for the wasteboard is 4.318mm. Why the limitation, and more importantly, how can I bypass it, or set it to a more reasonable value? (a wasteboard that starts off at 6mm and cannot go below 4.318mm lasts about 1 day.)
Intel Core i7-5820 3.3GHz, 16GB RAM, NVidia Quadro K2200 4GB, Windows 8.1 Pro 64 bit
Re: Wasteboard minimum thickness
Postby Kerry Fullington » Thu, Jan 21 2016, 1:14PM
Jeremy,
If the wasteboard gets too thin it allows too much air through and affects hold down.
that being said I changed ours from the .17" to .15 and I get a little more life out of the board.
You change it in the THM.ini file
Jeremy Schiffer
Postby Jeremy Schiffer » Thu, Jan 21 2016, 1:31PM
Thanks!
