changing rendering color 1 side
Mike Lew
Postby Mike Lew » Sun, Feb 21 2016, 3:50PM
I have a customer that wants to see color changes frequently. Is there a way to change the color on just 1 side of a display cube?
tim lucas
Re: changing rendering color 1 side
Postby tim lucas » Sun, Feb 21 2016, 6:59PM
Mike, if it is just the cube, I don't think you can change 1 side
but if it is the cabinets or walls - right click on the room and select modify textures
Tim
www.TLCW.us
Mike Lew
Postby Mike Lew » Sun, Feb 21 2016, 9:58PM
Yes Tim, it's just the display cube. Too bad there wasn't a "copy & paste" for colors, wood-grains, etc.
tim lucas
Postby tim lucas » Mon, Feb 22 2016, 7:53PM
Mike
I added a 12" square display cube to a room and gave it a cherry wood texture - to change the color in the room while in render mood just right click the mouse and select Modify Texture then select whatever color you need then render again
Hope this helps a little
Tim
www.TLCW.us
Mike Lew
Postby Mike Lew » Mon, Feb 22 2016, 8:12PM
Thanks Tim, I have a commercial laminate column they want different colors on each side.
tim lucas
Postby tim lucas » Tue, Feb 23 2016, 7:25AM
Mike Lew wrote:Thanks Tim, I have a commercial laminate column they want different colors on each side.
I would make it out of a cabinet using 4 different sheet goods and then you can still use the texture modify and change each side to what you want
www.TLCW.us
Users browsing this forum: No registered users and 18 guests
