built-in bookcase
built-in bookcase
Hey, just wanted some advice- attached is a built - in which is destined for my living room wall, as shown. But FIRST, I need to display it at our local builders show. I want to set it up in my 12x12 booth without having to build a2x4 wall, set a window etc... soo, I was thinking it would look good against the 8' curtain in my booth, but I would like to \"tie it all together\" with an arched valance at the show perhaps, although it would simply be two seperate cases once in my living room, with crown returned into the wall. My question is, what type of valance do I build that is cost-effective (since it will not be used in the final resting place), or does anyone have ideas other than a valance that will make the piece look good as displayed at a show?
- Attachments
- built in bookcase living room.jpg (85.76 KiB) Viewed 8478 times
Hi Dana,
Nice set up. first I'd ask if you do many shows? If so, perhaps a piece you could re-use as something else. Just add an additional tier over the top with low voltage or battery operated lighting to highlight your work. Or for simplicity, you could just run a 5/4 top bullnosed over crown over 1X facia The additional piece could be re-used as above or as a display table in the future.
Ed
Ed
Back to the wall
What about 1/4\" ply with crown. It would be very light
Thanks George for the great ideas! Below is my improved display, complete with \"curtain look\". I think with some soffit lights in the valance it will be quite an eye-catching display. Which Brewster file did you get your curtain look from?
Dana
Dana
- Attachments
- Builders Show display.jpg (150.81 KiB) Viewed 8401 times
