Moving a wall in room editor
Postby Donald Thomson » Thu, May 12 2016, 11:56AM
Once I've got walls in a room and cabinets associated to those walls, is it possible to move the wall and cabinets in the room editor?
I've got some walls that are to close together to view them in 3D. I need to move the walls further apart.
Thank you!
Ralph Balanik
Company Name: Ralph Balanik
Re: Moving a wall in room editor
Postby Ralph Balanik » Thu, May 12 2016, 3:01PM
Don,
I am not sure about moving walls but for viewing purposes if you highlight the wall and right click I believe it gives you the option of hiding that wall and its associated cabinets.
Ralph Balanik
Postby Ralph Balanik » Thu, May 12 2016, 3:06PM
Sorry Don,
You have to render the room and then right click the wall before you hit presentation view. It gives you hide options .
Postby Kerry Fullington » Fri, May 13 2016, 7:20AM
Donald,
I don't think you can move them together but select the wall and then mouse over both ends of that wall and a blue node will appear. Click on the blue node on each end and it will turn red. Now set the Object Move increment to the distance you want to move the wall and press the shift key and an arrow key to move the wall. Select all the cabinets that were on that wall and use the shift key and arrow keys to move them the same direction. I would re-associate the cabinet to the wall after moving.
Users browsing this forum: No registered users and 13 guests
