Constraint Manager - help needed
Postby Donald Thomson » Tue, Mar 07 2017, 2:04PM
I am designing a pull out tray for cabinets (drawer box). I have a half moon cut (PE) in the front part of the drawer. It is set to a certain width, say 5" wide. Tray (drawer box) file is attached.
I'd like to constrain the half moon to 5" wide but have eCabs auto center it in the drawer front. Is there a way I can set CM constraints to keep this half moon PE cut centered in the part when I add the pull out tray to a cabinet? If the pull out tray ends up being 22" wide or 28" wide, I'm interested if CM can keep that half moon centered without me having to manually recenter it after the tray is added to the cabinet.
Thanks in advance.
5-8 Aplply 1-2 inch bot TRAY with blum cutouts.hsf
(262.02 KiB) Downloaded 69 times
David Egnoski
Re: Constraint Manager - help needed
Postby David Egnoski » Tue, Mar 07 2017, 2:50PM
Try this one.
(256.02 KiB) Downloaded 76 times
Dave Egnoski
Richmond Cabinet & Millwork
Postby Donald Thomson » Tue, Mar 07 2017, 5:12PM
Thanks Dave!! :beer:
How do you get the formula in the constraint? That's exactly what I was looking for and couldn't figure out how to do.
David Egnoski
Postby David Egnoski » Tue, Mar 07 2017, 6:45PM
No problem, Donald.
Click on the "Edit" button in Constraint Manager then "Edit Constraint". Click on the constraint you want to edit. In the textbox to the right of the blue text enter the formula h/2.
Dave Egnoski
Postby Donald Thomson » Tue, Mar 07 2017, 7:23PM
Ah. For some reason I thought that box was for numbers only. Live and learn.
Thanks for your help!!
Users browsing this forum: No registered users and 16 guests
