Added option to import DXF polylines as lines or as arcs (Enhanced)
Scott Marshburn
Post by Scott Marshburn »
I tried to use this option but the geometry is still imported as line segments. has anyone used this feature?
Clint Buechlein
Company Name: Thermwood Corp
Re: Added option to import DXF polylines as lines or as arcs (Enhanced)
Post by Clint Buechlein »
Scott Marshburn wrote:I tried to use this option but the geometry is still imported as line segments. has anyone used this feature?
Scott,
If your geometry coming in is line segments, it won't convert them to arcs. There was an issue found that sometimes when bringing in a DXF, the reader for DXFs would break some arcs into line segments. If we did a full update on the reader, polylines wouldn't work as they were previously. So to keep everyone happy, a toggle was added in.
David Giesbrecht
Post by David Giesbrecht »
Just wondering were to find the toggle, could someone post a screen shot? Is it just when poly lines are detected?
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
David Giesbrecht
So this is the poly line I am trying to bring in, and it breaks it into short lines.
David Giesbrecht
Z270x-Gaming 5 MOBO
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
The polyline has to be originally created with line and arc segments. A "spline" like you have illustrated will be broken into small lines as there are no original arc entities which define it.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Clint Buechlein
David Giesbrecht wrote:Just wondering were to find the toggle, could someone post a screen shot? Is it just when poly lines are detected?
It is available in two places, Contour Mode of Part Editor, and Shape Manager.
Brad McIntosh
Here is an example of a polyline created with arc and line segments. Note: You need a panel of x=42, y=60.
PolyLine-Example-With Arcs.jpg (12.72 KiB) Viewed 15555 times
Polyline Test.dxf.txt
Remove the .txt extension.
(22.61 KiB) Downloaded 1187 times
Brad McIntosh
CNC Automation
David Giesbrecht
Thanks Brad and Clint. Also Ecabinets, great feature. The top one was a poly line the bottom was a spline.
David Giesbrecht
Z270x-Gaming 5 MOBO
