Corner door sizes
Rachel Meehan
Company Name: Maif kitchens and shopfitting
Country: AUSTRALIA
Corner door sizes
Post by Rachel Meehan »
Hi,
Wondering if anyone else is finding this problem.
We are using 6.2.2
We are making a 3 door corner cabinet and having issues with the doors.
In the door editor, I get the doors to the size I want for cutting (by using reveals) which is 290mm on the LH single door, and 295mm each for the RH double door.
Once they are correct in door editor, I return to the main screen, check the door sizes, and they have all increased by 2mm.
DFC LH problem.hsf
(452.02 KiB) Downloaded 661 times
Rachel
Re: Corner door sizes
Post by Forrest Chapman »
Rachel, I assume you're in beta? Moderators might wanna move this to the beta forum so you can get help. Only beta users can open the file so I'll take a look while I'm here to see if I can figure out whats going on.
Rachel, according to your reveal and gap settings the doors are coming out correctly. 292mm on the left door and 2- 296.5mm doors on the right side.
Here is the math for the left hand door. Left Front cabinet dim is 315mm - 3mm left reveal= 312mm- 18mm right door thickness= 294mm- 2mm for the door to door gap= 292mm.
The math works out the same for the right hand pair as I get 296.5mm.
Hope that helps, Forrest
