Is there a way to make doors with sheet stock panels ?
andy photenas
Company Name: woodland Kitchens NH
Post by andy photenas »
Hello all, I am still new to eCabs. Can someone direct me to how I would setup a door so that it's made from a sheet stock panel?
tim lucas
Re: Is there a way to make doors with sheet stock panels ?
Post by tim lucas »
Welcome Andy,
Yes you can by creating a board stock item with the same specs as sheet stock.
Tim
www.TLCW.us
Stuart Douglas
Post by Stuart Douglas »
Andy, Start by going to the door and drawer front designer using the button in the toolbar, then select the tab for the component you wish to design, door or front. use the source drop down bar to select slab. Go to the standard directory, then select the standard slab. Use the input fields to select the material and give it a name you can be familiar with. no when you apply doors or fronts you may select this option to put on your cabinets.
_____________
NVME SSM2HD 1TB NTFS
andy photenas
Thanks for the answers all! I am guessing you can't get a layout of the best way to cut the panels from a 4' X 8' sheet good like you can for all of the other parts of a cabinet ? seems a bit strange but ill go with it :)
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
Andy,
If you use Stuart Douglas' instructions, you should be able to get what you need.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Stuart Douglas
andy photenas wrote:Thanks for the answers all! I am guessing you can't get a layout of the best way to cut the panels from a 4' X 8' sheet good like you can for all of the other parts of a cabinet ? seems a bit strange but ill go with it :)
If your doors and fronts are all the same material they will nest together on a sheet. Be sure to set the defaults so that your fronts and doors are always the same material. You can specify if your material has grain, and if the parts need to be contiguous (matched grain). to keep things correctly laid out while maximizing the sheet yield.
_____________
Joe Soto
Post by Joe Soto »
I believe Andy is wanting a 5pc. flat panel door with hardwood rails and plywood for the panel.
tim lucas
Post by tim lucas »
Here is a slab door cabinet that will nest with the cabinet parts - all 3/4 plywood
Std Upper Framed.jpg (13.93 KiB) Viewed 19960 times
Std Upper Framed.hsf
(290.02 KiB) Downloaded 1793 times
Tim
www.TLCW.us
andy photenas
Thanks to all that help answer, I was so spun i did not ask this right and yes I am trying to make 5 piece doors with plywood panel. I am sorry for such a poor question and ty all for the help.
